Need a Built Trans
Old Nov 12, 2005 | 02:15 PM
ILL SUB's Avatar
Default Need a Built Trans
I am in the market for a new trans. I have a Yankss3600 stall, and pull 520hp to the wheels. This car is also my daily driver. I need a transmission that is built for the streat and strip and can take a beating. Anybody have some suggestions????
Old Nov 13, 2005 | 03:17 AM
Automatics's Avatar
Restricted User
Depnding on what you want, this should work well for you http://www.700r4l60e.com/store/custo...&cat=18&page=1 let me know if you have any questions.
Old Nov 13, 2005 | 06:32 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
Rock-On
I have his Stage4 with vacuum modulation - no problem whatsoever beating on the car with the numbers in my sig. Give Dave a call - extremely nice guy and they have the best customer service I've seen from a performance parts company.
BTW, the car he uses on the home page of the Rock-On site is my 'Phoenix' T/A
Old Nov 13, 2005 | 08:52 AM
Josh@KY-Turbo's Avatar
i am gonna be in the market soon for a built A4 formy planned 408 solid roller setup i am getting. i plan on some numbers in the 500's on motor and well into the 700's on the nitrous. i really want to keep my OD though.
Old Nov 13, 2005 | 01:24 PM
04Denali's Avatar
Go Rock on
Mark
Old Nov 13, 2005 | 08:15 PM
SgtB's Avatar
you sir I would recommend a TH400 witha GV if you want overdrive...700hp no 4l60e will hold..
Old Nov 14, 2005 | 03:45 AM
cablebandit's Avatar
go 4l80e instead
Old Nov 14, 2005 | 08:29 AM
i will more than likely do a 4l80E. i am not a fan of the gear vendors.
