Pics of a th400/GV OD?
I was wondering how well the GV OD worked under the car.... I mean with the torque arm, and in the tranny tunnel. I was looking at doing one after my current flp level 4 takes a dump(im not saying that it will....... but i'm putting a little bit more motor in front of it than I should)
What are the exact numbers on the gear ratios with the th400 and the GV OD(like the 6th gear ratio and stuff to)?
I know the th400 runs a 2.48 first, and I was thinking I can do the 2.75 ratio........ but does that mean the OD unit has to have a different first ratio too?
Josh S.
Josh S.
ya wouldnt happen to know what the ratios in second and third are with the 2.75 first? I want to say that they are the same as normal but for some reason i can't see that working very well..... but with the GV od it would help the little jump between gears.
if the th400 has a 1:1 in 3rd gear........ the OD makes it a what? like a .86:1 or so?
Josh S.
Josh S.
