torque management question
Old Nov 15, 2005 | 09:01 AM
LS69TA's Avatar
Default torque management question
For a daily driver, with just a few bolt-ons, what should I do with the torque management? I'm going to be getting a few things done like rear o2's and air injection turned off, and a few other settings changed. Nothing major. Just figured I'd do something with the torque management while I'm at it. It'll be a while before I put a stall in as well. Any suggestions?
Old Nov 15, 2005 | 09:05 AM
hellbents10's Avatar
LS1Tech Sponsor
If you are putting money into making it faster why would leave torque managment in it?????? Makes no sense to me cutting power on every shift. Its nice for soft mushy shifts and the occasional 50yr old lady that buys a F-body.
Old Nov 15, 2005 | 09:19 AM
LS69TA's Avatar
I've been too lazy to check into seeing what it actually does.
Old Nov 15, 2005 | 12:24 PM
jimmyblue's Avatar
Moderator
No, mushy shifts for little old ladies is the
line pressure settings and shift adaptation
time.
Torque management is how your engineers
delude themselves and management into
thinking a 600 lb-ft rated transmission can
survive behind a 350 lb-ft motor multiplied
by a 1.8:1 STR torque converter.
Old Nov 15, 2005 | 07:07 PM
LS69TA's Avatar
So should I just delete it all together?
Old Nov 16, 2005 | 12:56 AM
Automatics's Avatar
Restricted User
Talk to Ed Wright at www.fastchip.com he should be able to help you out on this.
Old Nov 16, 2005 | 01:09 AM
SmokingWS6's Avatar
I reduce mine 50 to 80% depending on gear during in the winter, its wiped out during race season.
