4L60E Housing Problems
Old Nov 18, 2005 | 06:58 AM
99blue-Z's Avatar
Default 4L60E Housing Problems
Was just wondering whether anyone else has had any problems with the tailshaft housing cracking. Mine cracked right in front of the trans. mount. I had it welded, and it cracked again, (I think the welding heated the aluminum up too much). Anyhow, I got a new one coming from GM (for a tune of $200, damn crooks) so it should be fixed soon.
Old Nov 18, 2005 | 08:39 PM
TeamTripp's Avatar
What kind of HP figure are you dishing out? Once a car gets fast enough, the Torque Arm mount needs to be relocated to take the strain off the housing.
Old Nov 19, 2005 | 09:35 AM
Yank's Avatar
WE have the HD F- body GM tailhousings
New for $75.00 shipped
mike@converter.cc
Old Nov 23, 2005 | 05:56 PM
99blue-Z's Avatar
i am only pushing maybe 360 hp. I have few mods done, so I don't know why it would be cracking.
Thanks for your help!!!
Old Nov 23, 2005 | 06:07 PM
Yank's Avatar
drive shaft balance, bad u-joints, poly mount, worn bushings in the transmission,pinion bearing, ponion angle and bent output shaft any of these can all be to blame.
let us know what you find
Old Nov 23, 2005 | 06:24 PM
PERFECT Z28's Avatar
Are you saying a poly trans mount could also cause this?
Old Jan 27, 2006 | 06:26 AM
99blue-Z's Avatar
Well, The new trans tail housing I had bought cracked again about a week ago. I'm thinking that my driveshaft is outta balance...
So I got a housing coming from 11SECSS, and I bought an aluminum D/S. I hope this solves my issue, if not I don't know what I'm going to do...
Old Jan 27, 2006 | 07:36 PM
orion565's Avatar
mine broke too, i got charged 250 from gm though, damn
Old Jan 28, 2006 | 10:07 AM
99blue-Z's Avatar
From what I have been told, this is another weak link on our beloved F-cars, but what can you do but try to improve upon GM's shortcomings I guess
