SS3800 Results
Old Nov 19, 2005 | 10:20 PM
Roarin_8's Avatar
Default SS3800 Results
So far with the nittos and the SS3800, I've managed to take a full second of my old time of 13.2. I believe that I can still squeeze more ET out of the car. Here is the thread
https://ls1tech.com/forums/showthrea...71#post3818671
Old Nov 19, 2005 | 10:35 PM
Superman09's Avatar
LS1Tech Sponsor
Wow, amazing man! Good job. Keep it up, 11's arent far. Your making me want to go buy my stall right now!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Nov 19, 2005 | 11:11 PM
Roarin_8's Avatar
Thanks. Hmmm have you seen the new superman teaser yet?
Old Nov 22, 2005 | 03:03 PM
Bad Blu Formula's Avatar
I'm hoping for 11.9s or 11.8s this fall. You post has made me a little more confident since I have a few things over you. My best so far has been a 12.2.
Old Nov 22, 2005 | 04:44 PM
ExceSSive's Avatar
What are your mods?
Old Nov 22, 2005 | 06:58 PM
Roarin_8's Avatar
If you get a decent sized converter you should be able to take off more than .5-.6 tenths. I took off a full second with the nittos and stall.
Old Nov 22, 2005 | 07:01 PM
BrianC98Z28's Avatar
my best time was 12.0 with Vig 3200 and boltons
Old Nov 22, 2005 | 07:05 PM
Roarin_8's Avatar
I need me some longtubes, nice dyno #s. I got just about the same 313 & 331 but those were locked #s.
Old Nov 24, 2005 | 06:23 PM
AK's WS6's Avatar
Damn!! I hope I have similar results. I did run it once on street tires and could only manage a 12.99 @106.76 with a 1.87 60'. I was finally getting a feel for how to launch, but the track was closing for the day
Old Nov 24, 2005 | 09:03 PM
Well, I basically have full bolt ons minus an LS6 or LSX intake. My car is also lowered on Hotchkis springs, but I have all the corresponding mods needed for it all to work except a torque arm. As for weight reduction, I have no back seat and run skinnies up front. I'll fill you guys in when I go to the track after ordering my MT drag radials.
Old Nov 24, 2005 | 09:14 PM
eric01ss's Avatar
sounds good man now get headers and ory or tru duals and look for 11's
i plan on that early spring when i get my stall in and tires
Old Nov 25, 2005 | 08:29 AM
rufretic's Avatar
That's a real nice gain!
"If you get a decent sized converter you should be able to take off more than .5-.6 tenths. I took off a full second with the nittos and stall."
I think you were able to cut that much off because you don't have all that much power and the 2.73s. Hooking makes all the difference. Once you mod more and start making more power and possibly change gears, the problem is finding traction. It will be much harder for someone with around 400rwhp to loose a full second off et with just a converter. I was only able to cut 1.6s with my SS4000, 3.73s and 399rwhp, thats why I just upgraded to hoosiers and a 12 bolt. 1.3s should be possible. If you plan to add power, get ready to start adding susspension and big sticky tires or you won't see the gains. Same goes for someone who already has the power, don't plan to loose a second off your et unless you can get it to dead hook.
Old Nov 25, 2005 | 10:06 AM
Superman09's Avatar
LS1Tech Sponsor
new superman teaser? Im looking to order a SS3400 or ss3600 here soon. Just for the fact i plan on getting a d1sc or sts kit here soon for about 6-8 psi. Should be the money. Lovin your results
__________________
Old Nov 25, 2005 | 11:49 AM
Roarin_8's Avatar
Yeah new superman teaser, the movie comes out next summer.
I won't change my gears and I make sure to be able to hook first than to add power first. Makes no sense to spend alot of money on power if it just gets wasted to the ground.
Old Nov 25, 2005 | 02:50 PM
Superman09's Avatar
LS1Tech Sponsor
Yea, my cars jsut a street car, wont see the track a lot if ever, i havent heard of that movie, ill check into it.
__________________
Old Nov 25, 2005 | 03:16 PM
rufretic's Avatar
Sometimes it takes more to hook up than you think. I have full susspension including a bmr extreme TA and QA1 shocks all the way around. I wanted to stick with drag radials because I like to drive on the street but they just couldn't handle it. I guess it's a good thing because it means my car hits real hard, just needed more tire. Next time out it's wheelie time.
Old Nov 25, 2005 | 03:27 PM
Roarin_8's Avatar
That's true but I don't hit the tires completely out of the hole. I just stall it up and let go of the brakes. If she spins, I'll just stall it less until she hooks and feather the throttle from there. I always try to see what the breaking point for the tire is and work around it. So if I don't spin on the street from a certain mph, I'll work around that at the track.
Old Nov 25, 2005 | 03:35 PM
rufretic's Avatar
Yeah, thats the way to do it. You have great times for your mods because it's a good combo. I was posting for the people that expect to drop a second off their et with a converter. That's a great gain no matter what converter, but it's not as easy as drop in the converter, loose a second, you have to get it to hook to get the full potential. 1.6 isn't bad for my setup but I think it's got a lot better in it.
Old Nov 25, 2005 | 07:14 PM
Ragtop 99's Avatar
2.73 gear cars respond very well to a converter. I'm amazed how many newbie's will swap the the 2.73s for 3.73s and gain .4 and lose the good highway MPG of 2.73s when a good 3200+ stall will net .6 or more. They also make good stoplight racing gears because they are easy to launch on street tires.
2.73s and nittos will hold a fair amount of power and as a factory rear holds up pretty well.
A nice set of headers and maybe a pulley or ported TB will get you to the 11s.
Old Nov 25, 2005 | 07:31 PM
Roarin_8's Avatar
Yeah headers and a built transmission will get me there easily. The car didn't spin when I launched at 4000rpm, but the trans couldn't hold it. Headers are next on my list.
