Post your 60ft times and what stall
Old Nov 24, 2005 | 03:39 PM
redsscamaroboy's Avatar
Raceweight 3650
Vig3600 E/T streets/no spin 1.72
SS4000 Nitto drl's/pedaled it 1.66
PT4000 Nitto drl's/rolled into it 1.61 All stock internal /N/A motor runs
Vig3600 E/T streets / no spin 1.54 150 shot wet
SS4000 Nittos/spinning 1.62 100 shot wet
PT4000 have not played with this vertor on spray really. Just changed to 3:42 gears with this vertor. Need more than Nittos to really hook it.
Dave
Old Nov 24, 2005 | 03:47 PM
RDTA's Avatar
1.52 on 28'' etstreet cam only pt4400 3.90 gear cam only 3540 race weight
Old Nov 24, 2005 | 04:23 PM
SuperSam's Avatar
Best sixty is 1.46 on 26, 10.5 by 16 M/T. 4400 PI Stall, 4.10 gears. 100 Shot.
Old Nov 24, 2005 | 09:26 PM
Dan's Avatar
Dan
3800 Vigilante, 1.66
Old Nov 24, 2005 | 09:40 PM
Bo White's Avatar
stock converter, street radials(nondrag) 245/50/16: 1.93
Old Nov 24, 2005 | 11:40 PM
MNR-0's Avatar
Fuddle 3000/2.0STR 1.71 60' 3.73 ET Radials (unopened)
Old Nov 24, 2005 | 11:45 PM
jessedale98's Avatar
3500 midwest , Nitto radials with 373's with a 1.64 60ft
Old Nov 25, 2005 | 12:22 AM
BrianC98Z28's Avatar
Vig 3200 275/40/17 Nitto Drags,3.42s and 1.65 60ft
Old Nov 25, 2005 | 01:32 AM
1 BLOWN V8's Avatar
TCI 3,200, 2.2 str, 342 gears with a 315/35/17 Nitto drag tires at 24 psi. Made 4 runs with a best of 1.66
Old Nov 25, 2005 | 01:43 AM
CamaroSS's Avatar
1.588 with a Yank SS4000......consistant 1.61s.
I have had trouble getting the car's suspension setup so....yeah.....it should have done better. 26" tire with 3.73s
New converter going in, the new Yank SE4400.
Old Nov 25, 2005 | 08:50 AM
hvyss's Avatar
Super Yank 3500 1.6 STR . 1.66 60ft on a 4400lb Impala SS.
Old Nov 28, 2005 | 12:16 AM
  #32
Elec87's Avatar
1.595 stock suspension with 200k on it even the stock torque arm. 28x10.5 et drags, 3.42 gear and a vigillante 4000 left from idle. I plan on stepping up the gear and droping the tire size.
Old Nov 28, 2005 | 12:22 AM
  #33
buffman's Avatar
Race Weight 4300lbs
Edge "streetedge" 3000rpm stall
Best 60ft to date is a 1.82. I'm in need of some better shocks and a stickier track.
I'm on 275/50/15 BFG DR.
Matt
Old Nov 28, 2005 | 04:17 AM
  #34
gccasper04's Avatar
1.69 art carr 3500 2.6 str
Old Nov 28, 2005 | 11:31 AM
  #35
SlickWillie's Avatar
PT4600 and stock suspension and it cut a 1.54....
Old Nov 28, 2005 | 04:50 PM
  #36
oztrack's Avatar
1.622 on SS3600 with 3.73 ET Street radials 235/60 x 15 - car did 11.765/115 at 3625lb
1.879 with SS3600 on F1 Eagle GS D3s in 245/40 x 18 - car did 12.445/113 at 3800lb
Consistently under 1.65 with ET street Radials and SS3600
Old Nov 28, 2005 | 06:29 PM
  #37
Holeshotz's Avatar
1.55 on a TCI competition 3800, 26X11.5X16 ET streets, 4l60e, 75 shot, 3:42's, no suspension work at all.
Old Nov 28, 2005 | 06:48 PM
  #38
rule 7 ss's Avatar
yank 3000, MT DR 275/40/17's, 3.23 gears, BMR ADJ Tq arm, stock suspension
60ft:1.644 75 shot
60ft:1.771 NA
Old Nov 28, 2005 | 09:55 PM
  #39
GregWS6&z28's Avatar
1.67 60'... Yank ST3800/2.5, BFG drag radials, 3800# race weight, 2.73's
Old Nov 28, 2005 | 10:13 PM
  #40
Spellbound's Avatar
My car.....(old set up) Yank ST3500 1.58 twice, on a bone stock rear suspension. Mostly mid to low 1.6's.
Girlfriends car.....TCI4400......1.57. Her old verter, Vig. 3200, mostly low 1.7's and a few high 1.6's. She picked up .5 going to the tci.
