do big stalls kill your top end
at least not from low or midrange speeds. i guess from a 120+ roll i might notice but who cares.
I know it's worth about 3-4 mph on my '91. I usually lock it up at the top of second gear (manual switch). This would also help in a 'frum roll' race I would think.
we put a yank st4000 converter in a stock TA. the mph went from 106 to 108 consistently but "lost" nearly 20 rwhp on the dyno.
to a Yank SS3600
picked up .3 in 1/4 and 2 mph
From a roll ........that 3600 was a BIG improvement over the 3000 but then again the 3600 has a higher STR of 2.5 so it hits harder
and im going with an EDGE converter
to a Yank SS3600
Holding all else equal (same engine, same tires, same suspension, same road/track conditions, etc), if you had a stock converter and went to a high stall, that's only two points that you can collect data for. Perhaps more stall or less stall would work better with your setup. Just because your ET drops and your trap speed increases doesn't mean you found the ideal converter for your setup.
Some converters are more efficient than others. The higher the stall the more inefficient it is at peak power. But what you lose from the top top you give to the bottom by way of torque multiplication - getting you out of the hole real quick.
The 21 blade stator on its own is irrelevant to determining how efficient a converter is. The combination of the impellor, turbine and stator and engine torque will yield a specific efficiency at high RPM. You can mix and match stators and impellors (pumps) to yield the same stall RPM, but they will deliver different efficiences and torque multiplication.
As said above, it depends what you want to do. What do you want out of a converter? Theres so much info here try doing a search on "converter efficiency".
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
