do big stalls kill your top end
Some converters are more efficient than others. The higher the stall the more inefficient it is at peak power. But what you lose from the top top you give to the bottom by way of torque multiplication - getting you out of the hole real quick.
The 21 blade stator on its own is irrelevant to determining how efficient a converter is. The combination of the impellor, turbine and stator and engine torque will yield a specific efficiency at high RPM. You can mix and match stators and impellors (pumps) to yield the same stall RPM, but they will deliver different efficiences and torque multiplication.
As said above, it depends what you want to do. What do you want out of a converter? Theres so much info here try doing a search on "converter efficiency".
Example, My friend had a 2001 Z28, automatic. With boltons, stock stall, 3.73's he went 12.12@115mph
He put a 3600 converter in and went 11.95 but his MPH dropped to 111. He was also slower at racing from a roll.
your friends car seems exactly like mine.....i juct installed my 3600 and i too feel like i am slower at a roll and not as strong up top??? no times yet though
now on a full top speed run (ricer style) on the highways, you will get eaten up by a stock converter car once the stocker catches up.
we put a yank st4000 converter in a stock TA. the mph went from 106 to 108 consistently but "lost" nearly 20 rwhp on the dyno.
run together. Efficiency costs you the MPH. The difference
between a 112 and a 110MPH trap, is a 1% less efficient
converter. There's a lot more span, in the converters I have
logs for, than that. Not to mention differences in how fat
the "good region" of efficiency is (higher stalls are peakier
in efficiency, may not even reach peak before your upshift
point, while a lower stall can hit a 97% flat-top and stay
tight for a while).
Design choices alter the tradeoff but efficiency, and efficiency
curves, are seldom shown and seldom asked about. Yet this
is where you lose top end HP. People are more concerned with
raising the weaker low-end HP (times) than what they lose
up top (trap) because time wins the race.
I'd say the difference is in the LT1 and LS1 power band. A high stall actually takes a LT1 out of its power band some. LS1s really start to shine above 4000.
Converters are freakin weird. Some gain mph, some lose mph, im so glad I dont have to deal with that
I havent tracked the car yet, but i have noticed that the top end hasen't really been affected dramatically..... for example, i raced a c6 with a hurting motor, (stock ls1 manifold, bad broken springs...yeah, i know....but i didnt know until i got home that night!!
) pulled a two car lead didnt budge from there. THe MPH difference wasnt climbing like before but enough to stay in-front. I havent tracked the car yet, but i have noticed that the top end hasen't really been affected dramatically..... for example, i raced a c6 with a hurting motor, (stock ls1 manifold, bad broken springs...yeah, i know....but i didnt know until i got home that night!!
