tranny problems help!
Old Dec 27, 2005 | 09:40 PM
96lotbss's Avatar
Default tranny problems help!
I have a problem when im in drive and I floor it and try to shift to overdrive.It red lines and wont shift can someone help me.
Old Dec 27, 2005 | 10:32 PM
exstanger's Avatar
I'm not sure about this but on some cars they won't shift into od at wot.
Old Dec 27, 2005 | 10:43 PM
MattZ28's Avatar
Will it finally shift into OD if you let off the gas a little bit? Sounds like the tranny is slipping.
Old Dec 27, 2005 | 10:58 PM
96lotbss's Avatar
Sometimes it will shift if i left of a little.
Old Dec 28, 2005 | 12:31 PM
andy1h2004's Avatar
Sounds like your transmissions going out, welcome to the club, check your neutral safety switch too; mine was giving me problem then that caused my transmission to go. . .So good luck!
Old Dec 29, 2005 | 04:24 AM
Automatics's Avatar
Restricted User
If the transmission is still in decent shape (3-4 clutch pack) the "modified" Trans-Go Performance Shift kit can solve this in most cases.
Old Dec 29, 2005 | 10:31 PM
96lotbss's Avatar
well im going to get it check and if its in pretty good shape.Ill just slap on the shift kit and see what happens.
