Has anyone done this with stock trans?
Old Dec 28, 2005 | 08:38 PM
ws6sojuiced01's Avatar
Default Has anyone done this with stock trans?
Has anyone run there stock trans into the 10s with converter only?
Old Dec 28, 2005 | 09:18 PM
ronan's Avatar
as-in stock internals na with only a converter? no....bolt-ons with a converter yes, cam only with a converter yes...
Old Dec 28, 2005 | 09:38 PM
They can have anything on the car they want just stock trans with a converter.
Old Dec 29, 2005 | 12:22 AM
rule 7 ss's Avatar
my stock trans and yank3000 both took a dump with the best N20 pass in my signature..(yes I fried a yank, and they say it's impossible).......on my second trans now with a SS3600 yank
Old Dec 29, 2005 | 02:18 AM
Pimpium57's Avatar
Talk to 'GM Muscle', 10.1 on the stock trans w a Midwest 3500 'verter.
Old Dec 29, 2005 | 05:27 AM
Automatics's Avatar
Restricted User
Yes, it can be done, but be prepared to go thru the unit soon, as the torque & horsepower capacity "are not there". There are always exceptions to the rule, but I would not go against it. T As you can see, the small diameter torque converter & high stall are what are a "big" help in keeping this unit alive, before doing any internal modifications. This is something that I have been saying over the last 10+ years, that this is the "first" problem that needed to be addressed on any LT1 or LS1 transmission, is getting "rid" of the "heavy" stock torque converter, thereby reducing driveline "shock", this alone will help the transmission to shift quicker. In the LS1, by going to a 9.5" lockup, you will lose over 30+ pounds of weight, (quite a lot) some what more than the LT1 15-17lbs loss, still a vast improvement. I think that you can see that this is a "big" improvement, even before you start adding the HD components to the unit.
Old Dec 31, 2005 | 05:55 PM
ronan's Avatar
btw, i went bottom 11s na stock internals with a 4l60e with a yank pt4600 and 2900# race weight
