3600 vig
Old Jan 5, 2006 | 05:29 AM
artic-z28's Avatar
Default 3600 vig
I have a ms3 on the way. I got a 3600 vig and 3.23's.. im also spraying. Thats why I dont want too big of a stall. would my stall be big enough for the street and some track use? I wonldnt see why not ?
Old Jan 5, 2006 | 03:27 PM
artic-z28's Avatar
anyone...
Old Jan 5, 2006 | 09:23 PM
cablebandit's Avatar
the single disc Precision converters generally stall a little higher than advertised. On spray it will jump on up there. Hope you got a way to tune for that converter or you are going to be all over the rev limiter on the 2-3 shift
Old Jan 6, 2006 | 09:53 PM
Pewterpower's Avatar
I had a Vig3600 and did not need a tune. I never hit the limiter on any shifts at all. But each car can react a little differently. If you do need a tune, it won't be a full blown tune....just a partial, and shouldn't cost all that much.
Old Jan 7, 2006 | 08:05 AM
i think he is going to be running a little more power which will make the converter slip a little more which throws of the pcm sometimes.
