4L60E - Two gears at once
Old Jan 11, 2006 | 08:36 PM
34koop's Avatar
Default 4L60E - Two gears at once
If I select first gear on my box it feels as tho it is also engaging another gear. The car will not readily creep on idle like it does in drive.
It is also shifting into second well before the required speed in drive. It changes at 3500 rpm when it should be closer to 6000rpm. I have fiddled with the change at speeds for WOT and Part Throttle but it makes no difference. It is also hanging in second gear and not changing to third.
Car has a stock stall and B&M shiftkit.
Any ideas as it is driving me nuts
cheers
Mal
Old Jan 15, 2006 | 06:46 PM
34koop's Avatar
The 1=>2 accumulator piston was still the stock plastic one and had broken into three pieces held together by the o-ring. Was replaced with a metal one and so far so good.
Hope this helps someone else in the future.
cheers
Mal
