Bolting up an th350 to LS1
Old Jan 11, 2006 | 11:19 PM
QuickZ28's Avatar
Default Bolting up an th350 to LS1
Ok, im sorta new here so bare with me.
I am swapping a 6.0 liter into my thirdgen...And i have a built th350 already(from my last set up).
I was wondering what it will take to bolt the th350 to a 6.0l....Is it a direct bolt up? If not, what will it take to work.....?
Also, how would i get the tranny to work with the 6.0, in meaning to the kickdown cable....??
Any feedback is useful!!.....
thanks
Old Jan 12, 2006 | 12:45 AM
coop5885's Avatar
it will bolt right up, it just dosnt use all the bolts. I dont remember which ones dont get used off the top of my head.
I used a Th350 converter in it with no problems.
I dont have a kickdown cable on mine, so i cant help you there.
Old Jan 12, 2006 | 04:09 PM
QuickZ28's Avatar
So i take it you have a full manual valve body?......
does any have any ideas to solve the kickdown problem?
Old Jan 12, 2006 | 06:52 PM
ApacheDrill's Avatar
I cant help with the kick down either but i ended up getting a TCI flexplate as well that was universal.
Old Jan 14, 2006 | 02:26 AM
coop5885's Avatar
no, mine is vaccuum modulated.
Old Jan 14, 2006 | 02:40 AM
CAT3's Avatar
Restricted User
Either vacuum modulate, if you want an "automatic" or get a manly shift yourself-o-matic RMVB.
Definately replace the stock flexplate bolts when you do this operation. I have reused my stock ones too many times and now am looking to order the ARP ones used in an M6, which work fine since the TCI flexplate is thicker.
