T/C in LT1 VS LS1
The LT1 on the other hand makes 275 HP @ 5200 and 325 TQ @ 2400. The torque for the LT1 is alot lower in the rpm range so keeping the LT1 in its powerband takes alot less converter. Generally speaking, most LT1 guys run a 2600-3000 stall. Seems like 2800 is the most popular size I see going into them.
But adding bigger cam usually raises the powerband and thus the stall size can increase as well. I hope this helped.
