What effect will a Torque Converter have on normal driving?
responsive. You could really beastify it by going
big but let's leave that for your second converter.
The best thing is, you change from a "more pedal
doesn't do anything" (because you're coupled up
tight at low RPM and there's just no more torque
made from a more-open throttle) to a pedal-
proportional RPM slide and acceleration. Getting
a converter that matches the motor's nature is
nice. I found the TCI 3000 pleasant in this regard.
Similar would be the Yank SS3200 I expect, though
the SS3200 is probably a superior piece as far as
the clutch and maybe efficiency (though the TCI
delivered me about 97%). Something in this range
will still creep on the level, climb light grades at
1500-2000RPM unlocked but still let you slide right
up into the powerband when you push the pedal
and scoot.
Moving up to a 3500 I've found it less "intuitive",
needs more pedal and more RPM to go. Pulls harder
when you're well into it but not as "natural". It's
not as well matched to my stockish motor, but I
stepped up because (a) my clutch was pretty much
toast and (b) moving past stock engine config bit
by bit and figured I'd get ahead of that, a little.
Ed
in acceleration fuel economy due to lighter rotating
mass and less diameter. I wouldn't expect a whole
lot. But at least it won't cost you as long as it doesn't
slip (which is not to be taken for granted, some are
stronger than others).
