4l80E help with converter bolts
However, I remember those bolts are pretty meaty.... and there's 6 of them unlike some over converters... do you really think you're at any risk?? That's a lot of metal to go through!!
If it is internal the Summit P/N is: ARP-200-2902, $10.88
If it is external the Summit P/N is: ARP-200-2906, $10.95
These are both Pro Series ARP Flexplate bolt kits, 6 each.
I am using the 2902 pack on my 4L80E with an internally balanced engine. They are stout parts, and need a 12-point, 3/4" socket.
Jim
Fastener Material: Steel
Fastener Finish: Black oxide
Fastener Head Style: 12-point
Thread Size: 7/16-20 RH in.
Underhead Length (in): .680
Fastener Yield Strength (psi): 200,000
Washers Included: Yes
Quantity: Sold as a set of 6.
Notes: Fits with 3/4 in. socket.
I believe it is the flexplate-to-torque converter bolts that are metric, and you must use Metric Grade 10.9 because there are only 3 bolts holding the converter. I remember that Summit/ARP did not carry them and I had to go to a special metric store (Mr. Metric) here in San Jose, CA. They're like $1.25 each, and dark gray.
Jim
You are talking about which?:
- The SIX bolts that attach the flexplate to the rear of the crankshaft? These are Standard thread.
- The THREE bolts that go to the Torque Converter? These are Metric thread and must be Metric rated 10.9 or higher.
I am sure you have it right but want to make sure I understand it.
Jim
Do you only have 3 on your 4L80E? What model year is it out of?
Jim
