*HELP* shift solenoid locations
Old Jan 25, 2006 | 08:41 PM
JDM_99Z's Avatar
Arrow *HELP* shift solenoid locations
I was told that they are located on the outside of the valve body torwards the rear and you can see them when you take the pan off. Is this correct?
Old Jan 25, 2006 | 09:58 PM
TA TECH's Avatar
Yep there at the back of the pan area side by side small square solenoids held in by a small metal clips not much too them!
Old Jul 10, 2006 | 09:43 PM
tomz240's Avatar
When I pulled the pan and filter I see 2 solenoids. They look identical. How can you tell which one is the 1-2 shift solenoid????
Old Jul 10, 2006 | 09:55 PM
tomz240's Avatar
Default Help guys- i'm stuck with my pan down
Need to know how to identify the 1-2 shift solenoid.
