Need Help!
Old Jan 27, 2006 | 09:56 PM
2000RedZ's Avatar
Default Need Help!
I'm doin a torque converter install and the tranny will not come off the damn dowel pins. I've sprayed them with WD-40, tryed pryin on the tranny, and hit it with a rubber mallet. But it still wont budge. Anyone got any ideas on how to get it out of there
Old Jan 27, 2006 | 10:18 PM
FLT's Avatar
FLT
Did you see the post on DOWEL PIN HELP!!!! Check it out, most off the info and supplies your looking for are there. Including cold beer!!! Yum BEER.
Old Jan 27, 2006 | 10:22 PM
2000RedZ's Avatar
ya i looked there but ive tried all those things and still no luck
Old Jan 27, 2006 | 10:42 PM
FLT's Avatar
FLT
I know this might sound nuts, take a screw driver, place it between the block and bellhousing. Hit it with a hammer driving it between the two. This should start to seperate the two. Just make sure everything is unbolted first. When it starts to split wiggle,pry, swear,bitch and then slowly lower to the ground. Last step is get a cold beer! Hope this helps...
Old Jan 27, 2006 | 10:52 PM
2000RedZ's Avatar
alright thanks ill try this hope it works
Old Jan 27, 2006 | 10:54 PM
80superbu's Avatar
Did you take the driveshaft out
Old Jan 28, 2006 | 01:11 AM
2000RedZ's Avatar
I'm pretty sure i got that
Old Jan 28, 2006 | 07:12 AM
FLT's Avatar
FLT
Did you get SOB out yet?
Old Jan 28, 2006 | 07:48 PM
2000RedZ's Avatar
No not yet tried everything i think any other ideas
Old Jan 28, 2006 | 11:44 PM
The Sad's Avatar
I have hooked a come-a-long to the tranny (on the torque arm mount) and to the rear end, then winch away. I would try the screw driver wedge/pry technique again first.
Old Jan 29, 2006 | 12:22 AM
2000RedZ's Avatar
Well got half half of the tranny un stuck but ill try more tomorrow
Old Jan 29, 2006 | 07:07 AM
FLT's Avatar
FLT
Sounds like the MF is just about ready to fall out of there! Take a little tension off the jack,wiggle,pry,bitch,swear,BOYAA! It's out of there!! Don,t forget the last step once it's on the ground! Sounds like you really earned it. Cold beer yumm! Keep us updated, hope in the end it's all worth it!
