Can I put the temp sender in the pressure port?
Moderator
@fst100: The experts are telling you it will only read the case temperature because there is ZERO fluid flow through that area. While the temperature transducers in the cooling lines might be the most accurate, the only other method is a sensor in the oil pan as the experts are telling you.
