Can I put the temp sender in the pressure port?
Old Jan 31, 2006 | 01:54 AM
Black X's Avatar
Default Can I put the temp sender in the pressure port?
Hey guys like the title says, Can i install the temperature sender in the Pressure port on the side of the trans?
Its an autometer guage.
Attached Thumbnails Can I put the temp sender in the pressure port?-dsc00425.jpg
Old Jan 31, 2006 | 07:12 AM
K9 Pusher's Avatar
That is where most folks put the temp sender. Seems to be pretty accurate.
Old Jan 31, 2006 | 07:54 AM
GregWS6&z28's Avatar
yes. easy to do, no adapters required for the sender
Old Jan 31, 2006 | 09:16 AM
BubaGumpShrimp's Avatar
thats where i put mine, threads right in and pretty accurate
Old Jan 31, 2006 | 07:16 PM
slimcracka's Avatar
buba what was your mph in that 13.0 run?
Old Jan 31, 2006 | 09:58 PM
it was 107 mph
Old Feb 5, 2006 | 11:34 AM
Tiger2o69's Avatar
does anyone know how close the temps are with that vs atap or hptuners, ect?
Old Sep 7, 2023 | 08:54 AM
fst100's Avatar
reviving an old thread, whats the thread size/pitch for that pressure hole? i just installed a th400 in my 01 ta and am in the process of installing some sort of a temp gauge, maybe autometer or equus?
Old Sep 7, 2023 | 09:12 AM
MaroonMonsterLS1's Avatar
1/8 NPT
But it's really not a good place to put a temp sensor
You'll want to put the sensor in the pan
And if you want to get fancy, put a thermocouple in the cooler line outlet port right off the case
Old Sep 7, 2023 | 10:30 AM
FranksCustomTrans's Avatar
LS1Tech Sponsor
I agree with MaroonMonster not the best location. It is a dead end port so really you are measuring case temp not fluid temp and reaction time will be much slower and temp very affected by outside conditions, proximity to exhaust ect , The pan is best location for good average temp. I have considered but not worked on the idea of calibrating a gauge that could be spliced into the harness to use the sensor in the manifold pressure switch does not seem it would be too difficult to calibrate which would be an even cooler idea IMO
__________________
Old Sep 7, 2023 | 11:34 AM
TrendSetter's Avatar
Originally Posted by MaroonMonsterLS1
1/8 NPT
auto meter sells a stubby temp sender that works well for cooler lines
part number is 2259
Old Sep 7, 2023 | 12:27 PM
Those sensors can be slow to respond and they often don't read high enough temp for any performance unit really putting the converter to work
30-50 degrees per second for a turbo car on the 2 step and then that same 30-50 per second for a car really working hard going down track
Not uncommon to see 500+ degrees coming out of the trans!
Old Sep 7, 2023 | 01:39 PM
fst100's Avatar
the trans is already in the car and running lol. i dont want to drain and drop the pan to drill/tap for the sender anytime soon lol.
Old Sep 7, 2023 | 05:23 PM
pdxmotorhead's Avatar
Low dollar motorsports sells a Pressure/temp combo sensor that threads in to the transmission. test port.. I'm using a couple of their sensors they seem to work ok.
Old Sep 7, 2023 | 05:28 PM
fst100's Avatar
is the test port on the driver side of the case by chance?
Old Sep 20, 2023 | 03:48 PM
fst100's Avatar
Can't get the needle to move at all after installing the sending unit on the return line. im using the bolt that's connected to the sway bar bracket. Touching the rubber hose area is warm to the touch just like the main line. What am I missing?
Old Sep 20, 2023 | 07:54 PM
vorteciroc's Avatar
What I often used for a Pan Mounted (ATF Aggregate Temp) Sensor is:
GM: #10096136.
It is a GM Gen-II SBC LT1 Engine Oil Temp Sensor, 1/4 NPT, Can be read by GM or Holley EFI Controllers.
I also like that I can used a Sealed and Booted Electrical Connector with it.
Old Sep 21, 2023 | 11:21 AM
Yes, right now I use the internal trans temp sensor on the 4l60 , but I am reading pressure live off the test port..
It helped me just verify a new trans was behaving when I was getting the setup tuned..
I have a Holley Term X max for engine and trans control. Seems to be working well.
Old Sep 22, 2023 | 03:05 PM
fst100's Avatar
After few attempts to get the gauge to read the sender on the return line with no luck trying to get a decent ground connection, I went ahead and used the test port on the driver side of the trans and wouldn't you know it the needle started to move after a short drive around the block.
After checking for any leaks I went out for a cruise on the freeway, the needle was reading steady just above 190*F as my coolant was reading 200*F. would of thought the temp be lower at around 180.
Old Sep 22, 2023 | 07:58 PM
LS1Tech Sponsor
Its a dead end port, You are actually seeing the case temperature which will tend to be higher or lower than the actual fluid temperature depending on external conditions.
__________________
