Problem with transmission on my A4....I think?
I have a 2000 Z28 with 3.23 gears. (SY3500 converter, Transgo Shiftkit, Trans Cooler)
My car is shifting at 5100Rpms on the 1-2 shift and it should be shifting somewhere in the 5800-6000 range.
Also, last week I was testing the car to see how fast I could take it up to. As I was at WOT in 3rd gear my car hit the rev limiter and would not shift into 4th gear. I have to let off the gas for a second then my car will finally go into 4th.
These things started happening after I had my Torque converter installed with a trans cooler and shift kit. Could it be a Torque Management conflict or something?
Any ideas as to what is wrong??
Thanks for any help
Chris <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
<strong>Make sure fluid is not low. When I got my car back after TC install it would hit the limiter on the 2-3 shift. I was only down 1/2 quart.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Same here! Down 1 full qt. Would not shift 2nd to 3rd.
