Request for Vig3200 AutoTap files
Old Mar 20, 2002 | 11:24 AM
JNorris's Avatar
Moderator
Default Request for Vig3200 AutoTap files
I recently installed a Vig3200 in a bolt-on car and I would like to compare my ¼ or 1/8 mile runs with the converter to others with the same converter and preferably with 3.23 gears.
So if any of you all have this combination and would not mind emailing me a copy of them or just post a link to the files I would really appreciate it. Any file format is fine. I am looking to see how high the converter flashes.
Feel free to look ant my ¼ mile runs at the link below.
Vig 3200 runs
jnorris404@aol.com
Thanks
John
<small>[ March 20, 2002, 11:24 AM: Message edited by: JNorris ]</small>
Old Mar 20, 2002 | 05:31 PM
98TAauto's Avatar
Default Re: Request for Vig3200 AutoTap files
atap really isnt gonna be fast enough to keep up with the stall flash.. it may be off 200-300 rpms
but with my 3600 if i floor it, on atap it jumps to 4200... 3.23's also <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 21, 2002 | 06:16 AM
JNorris's Avatar
Moderator
Thanks.
Old Mar 21, 2002 | 06:49 AM
99BlueZ28's Avatar
Did you figure out your elapsed time for 0-60? Just kinda curious how I compare with your converter? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Also. From what I understand, autotap is most accurate when you only log a few things. Maybe try logging a few options to see if there is any truth to this. I could be wrong but I remember hearing that somewhere. Anyone?
<small>[ March 21, 2002, 06:52 AM: Message edited by: 99BlueZ28 ]</small>
Old Mar 21, 2002 | 08:26 AM
JNorris's Avatar
Moderator
Using the calculator at the below link my 60’ mph is 49.65. But that seems kind of high. It seems strange that in the 1st 60’ you can get to 50mph but you need another 1260’ to get to 112mph.
Link
http://prestage.com/carmath/calc_60.asp
John
Old Mar 21, 2002 | 09:37 AM
Reboot's Avatar
Just curious are your shift points stock or modified with programming? If modified what are the setting?
Old Mar 21, 2002 | 03:55 PM
Reboot's Avatar
Thanks! My new FLP tranny is going in today. If I can put a couple hundred miles on it by Saturday, I will borrow a buddies ATAP and make a couple 1/4 mile passes.
Old Mar 22, 2002 | 12:05 AM
JNorris's Avatar
Moderator
1-2 shift is +2 using a HPP
2-3 and 3-4 are stock
Old Mar 29, 2002 | 08:59 PM
JNorris's Avatar
Moderator
TTT
Old Apr 1, 2002 | 09:47 AM
Lane's Avatar
JNorris - I have my shift points set the same with 3.23 gears as well - and the best I can tell, my converter is flashing in the upper 3K's.
Old Apr 1, 2002 | 08:07 PM
JNorris's Avatar
Moderator
Lane – Thanks for the info. WOW! The upper 3Ks. I see nothing like that. The most I have seen is almost 3100. I had the converter pulled out and have sent it back to PI to see what the problem is. Do you have any AutoTap files of the converter flashing?
Thanks
John
