Very rough 1-2 shift, no DCTs, need help!
Intermittently the 1-2 shift feels like i got rear-ended. Sorta like if you were stationary and reved the car up in N and dropped it into gear, that same surge you feel and kuh-lunk of the drivetrain sucking up the torque. It isn't noticable in WOT conditions or if i really get on it, but is more likely if i just ease off the brakes and am taking it easy. And it doesn't happen all of the time. Car has about 65K miles, i just got it last year so don't know the history. The ATF is at correct level and appears to be nice and clear and correct color. No DTCs are thrown for the tranny. Anyone have any idea what the problem is, how to fix it? Thanks in advance!!
Good luck
Thanks again!
Start worrying when the shifts are coming late and hitting really hard...or when you can just barely feel them at all.
Should i consider beefing anything up while i'm at it?
Thanks again all commenters. Saving me a lot of dough.
There is an easy fix for it, unfortunately you will have to remove the valve body. A good trans guy can drill out the bore and replace the valve with a larger one and change the spring, not only does this fix the problem, but it gets rid of the PWM also. This means when it goes into OD it will immediately go into lock-up, instead of slipping in.
This may not be your problem, but its worth looking into, ive seen it happen many times in the past.
Good luck.
I called a few tranny shops. First guys says it needs rebuild but last guy i talked to said valve body and he can do it for $200 in a few hours, with new filter and ATF (remember i'm in Hawaii before telling me this is a rip-off). He seemed much more knowledgable and predicted it would throw DTC 1870 so i'm going to talk to him right now. Thanks again for all of the input everyone on this thread.
Paul
Since i've been programming the car and it was in SD mode while i have been logging my fuel trims to adjust the VE table, i re-enabled my MAF before taking it to him. I did experience the "surge" on the 1-2 once on the way home but have put about 2 hours of driving on the car since then and it hasn't shifted rough once since. I called him and told him about the 1 time and he said if i bring it in he'll take another look at it, but it hasn't happened again.
A friend of mine here suggested maybe just a bubble or something from having the fluid and filter changed and if it doesn't happen again i'm good to go? What are other's thoughts, does that make sense?
Regarding line pressure during SD mode, i have no idea but it definetely shifts stiffer and with this rough 1/2 shift in normal mode in SD it was a killer, felt like i was getting rear-ended. Maybe i should start another thread and see if anyone knows what is exactly happening with shifting in SD mode with the A4. I haven't put it back in SD mode but was planning to do so after i've driven some more with the MAF just to make sure the tranny problem is licked.
Thanks again for all who contributed to the thread--it was really helpful in picking the right shop--even if the car isn't fixed yet i think Wayne is the guy to help me get it right.
