Too Much for a 4L60E?
Old Feb 14, 2006 | 01:52 AM
transaman98's Avatar
Default Too Much for a 4L60E?
Alright guys...I am about done having a bunch of mods done to my car and I was wanting to know what some peoples opinions were on if it would be too much for my stock A4 4L60E to take. Heres A list
Long Tubes w/ no cats, loudmouth catback, agressive cam, 3200 stall, ported stock heads, timing chain, tranny cooler, chromeloy pushrods, double springs, ferrea valves, roller rockers, shift kit, Cold Air, injectors, and 150 shot to top it off. I used to have just the 150 shot and loudmouth on it. Even then I thought it ripped, but im just beginning to wonder if the tranny is gonna hold. I already know my rear is gonna go when I put some sticky tires on it. I am in the process of gettin set up w/ a strange 12 bolt w/ 4.10's. Let me know what you think.
Old Feb 14, 2006 | 03:31 AM
Automatics's Avatar
Restricted User
If you spray it with nitrous, make sure you use a "window" switch" setup. This will stop the nitrous during the shifts, and the transmission will live longer, even with the other modifications.
Old Feb 14, 2006 | 01:48 PM
Z2K_MrJ's Avatar
Board Certified Idiot
IF your car was tuned allrdy with your Cam Install . I would get it retuned if your going to try and SPRAY using a wet shot. ALSO dont spray threw the shifts . your tranny should hold up
Old Feb 15, 2006 | 12:05 AM
yeah i already have a msd window switch...and that thing has saved my *** a couple of times...but as far as the tuning goes...the vehicle will be tuned again after everything is said and done.
Old Feb 15, 2006 | 04:00 PM
orion565's Avatar
mine didn't even hold 379 for over 5k miles from 22k-27k on an 02, with no street racing and no track, hmm, I lost 3-4, I assume that is what will happen with that setup too.
