Transmission Seals
Old Feb 16, 2006 | 05:45 PM
Ls1Envy's Avatar
Default Transmission Seals
How many of you replaced the Front and Rear seals when you did your TC swap? I heard that 80% of the people don't change them. My car has 60k miles so if its gonna be a PITA to change them out, i won't do it. Any tips on this install would help too. thanks
Old Feb 16, 2006 | 06:04 PM
zeeya94's Avatar
Its a good time to change it. A hammer and a small flat screwdriver will do the trick. When you put the seal back in. Get it as flush as you can. Good luck.
Old Feb 16, 2006 | 07:26 PM
rgriffin's Avatar
I learned my lesson the hard way. A leak sucks and doing it over b/c of a leak sucks even more. So do yourself a favor go buy the seals and spend the extra couple of minutes to put them in.
Old Feb 16, 2006 | 08:44 PM
Ls1Envy's Avatar
Yeah, It's probably good preventive maintenance. What about the pan gasket. Is that reusable?
Old Feb 17, 2006 | 06:21 AM
zeeya94's Avatar
The pan gasket dosnt need to come off. Unless your are going to pull the pump ad change the bushing. And how cheap the filter kit is I would just buy a ew kit and install it.
