Stock Auto Trans Cooler?? Never seen one...
Old 02-22-2006, 06:08 PM
99ssleeper's Avatar
Default Stock Auto Trans Cooler?? Never seen one...
Ebay auction...
Is that a WS6 thing? My SS did not have one of these...
Old 02-22-2006, 10:19 PM
Blk02Ls1A4's Avatar
I think the guy is full of it. The only tranny cooler our cars have stock is the one inside of the radiator.
Old 02-23-2006, 09:16 AM
BubaGumpShrimp's Avatar
thats not a trans cooler, its the power stearing cooler, an option on the ws6 package.
Old 02-23-2006, 02:37 PM
Blk02Ls1A4's Avatar
I though the power steering cooler was the metal section in the upper radiator hose that has the tubes going to the power steering. It is round in shape, looks nothing like that.
Old 02-23-2006, 05:08 PM
you could be right, i do know that auction is not a stock trans cooler.
Old 02-23-2006, 05:39 PM
strokedls1's Avatar
I have never seen a tranny cooler on an fbody from the factory. I have an 00' formula and the only optional cooler was for the power steering and is the tube like the one described above.
Old 02-24-2006, 01:39 AM
'Trust''s Avatar
All Auto LS1's came with Tranny Coolers, though I'm not sure if that is one of them.
Old 02-24-2006, 04:41 PM
the only stock tranny cooler is in the radiator, its not an external unit like the picture..
Old 02-24-2006, 10:08 PM
Red Heartbeat's Avatar
It may have been removed from a car but I doubt GM installed it since it does not have threaded fittings.
Old 02-25-2006, 10:09 AM
BanzaiEnt's Avatar
Default cooler
Hey Guy's
I'm the one that won that auction. I'll let you know wht it is when I get it.
I,m doing a M6 - 700R4 HD swap. Lazy do not want to shift all the time. Build these trans all the time. With the right parts they are strong. Do need info, part numbers for speedo parts.
2001 Z28
Red
M6 soon 700R4 HD
Touque Arm, Banzai Enterprises
HD Racing Motor Bay/Firewall Brace, Banzai Enterprises
Rear Shock/Spring upper Brace, Banzai Enterprises
2 1/2 Stainless Y pipe into a 3" Merge pipe, stock cats outlet removed and
inlarged to 2 1/2
Magna Flow exhaust (LOVE IT) Front of inter. pipe was inlarged to 3", not
2 3/4
3.73 gears
Power Coated calipers and rotors (just hub part)
Power slot rotors
PFC pads
Valvoline, syn fluid
Amsoil in trans, motor, p/s
Mecca fluid in cooling system
thermostat modified to open 180 deg
Computer,
Hurst shifter with shortened chrome handle
ZO6 wheels
275/35-18 295/35-18
Suspenshion tech springs
Suspenshion tech sway bars
All poly bushings, front end, rear end
Lakewood rear lower arms
Rear lower arm relocating brackets, (look like stock) Banzai Enterprises
adj. track bar with Hiems (no noise) Banzai Enterprises
KYB shocks
26 MPG
1996 Z28, Drag Car, Super Gas, Super Comp
Black, will be repainted Off White, Orange, Yellow
383 SBC, Banzai Enterprises
Powerglide, Banzai Enterprises
8" TCI
Full Tube Chassis, Banzai Enterprises
4 Link
9" Ford
Strange Struts
Being built as I type
If anybody has numbers for speedo parts let me know
Banzai
banzaient@bellsouth.net
Old 02-25-2006, 10:10 AM
BanzaiEnt's Avatar
PS
I emailed the guy to get info on cooler
Banzai
Old 02-25-2006, 10:48 PM
99ssleeper's Avatar
I used a B&M 24K GVW cooler on my ss and I never had a problem...always stayed between 160 and 190 in city driving. IMO, auxillary trans coolers are a must for any automatic, stock or not.
Old 02-26-2006, 01:51 AM
distortion_69's Avatar
Did the police optioned cars come with tranny coolers?
peace,
Josh
