50mph Roll Race-Need Help
Old Feb 26, 2006 | 11:03 AM
F-Body Garage's Avatar
Question 50mph Roll Race-Need Help
I do alot of racing from rolls on the street. One race that I'm lookin foward to is from a 50mph roll against a WRX that has about 450hp.
My car is in the process of getting Patriot Heads w/ TXSpeed Torquer Cam, and 150 TNT wet kit.
I just bought a TCI 3800 Stall Converter to accomadate for the larger cam.
What do you guys think I shoud do with the Rear End???
I have 3.23's for the car now, but think I should change..... what gear should I use if Im racing from a 50-130mph roll?? 3.42?-3.73? or stick with the 3.23's??? .........or go with a 2.73?
Old Feb 26, 2006 | 11:23 AM
slimcracka's Avatar
i would stay with 3.23 and if the rearend breaks THEN upgrade to a stronger 12 bolt.. dont waste your $$ on a gear swap expecially if your only goin to move up that much in gear and sence you race from a roll on the street!
Old Feb 26, 2006 | 12:18 PM
good point,
I just want to make sure the car will perform its best from a roll on the street.
I know I'm not the best canadate with an automatic racing from a roll and thats why this guy wants to race me. He says I have no chance.
His best trap speed was about 126mph! So I gotta make sure mine can hang top end....
Old Feb 26, 2006 | 07:34 PM
to the top!
Old Feb 26, 2006 | 08:19 PM
BlackHawk T/A's Avatar
I also say stay with the 3.23, which is what I am doing. My SS3600 will be more than enough for my tires and I don't feel like making a big dent in my mileage with a smaller gear. But then again not everyones application is the same.
But if you're racing top end, I would stay with the 3.23. Any more than that will put you into OD at WOT sooner, which has been discussed here to be BAD for your transmission. You really want to stay 1-2-3 for racing.
Old Feb 26, 2006 | 11:30 PM
obZidian's Avatar
Sure, stay with the 3.23 gear and when your gonna race drop it done to "d" Slam in the gas and hold on. You can either spray through the gear or srapy once in 3rd.
Also, as a onus, you can try to get a lock-up switch for the converter and hit it arounf 130-140 or top of 3rd....this way 3rd will lock and act like another gear, gaining in mph.
good luck, with a /c package and a 150 shot you should be fine. Just be careful of a 3-1 wot shift, spraying through the gears and wot into o/d.
good luck...get that punk!!! oh, and be safe!!!!
Old Feb 28, 2006 | 04:56 PM
Hey thanks alot guys! Ill let you all know how it turns out in a week or so.....
Old Mar 3, 2006 | 08:14 PM
the guy I'm set up to race just ran an 11.2 at 127.8 mph.
I hope I can hold him off long enough..
Old Mar 3, 2006 | 09:26 PM
slimcracka's Avatar
you got that with a bigger shot! lol
Old Mar 3, 2006 | 10:48 PM
TCI just sent me a 4000 stall instead of the 3800 is ordered..........
Should I send it back and get the 3800 or is someone trying to tell me somthing?????
Remember I'm using 3.23 and racing from a roll....do i stck with what they sent me or switch it back to the 3800?
Old Mar 4, 2006 | 04:09 AM
james562's Avatar
Gods tryin to give you every chance you can at a win. My vote is stick with the 4000.
Then again you didn't get what you ordered...
Old Mar 4, 2006 | 10:17 AM
obZidian's Avatar
Your 11.69, what stall were you running?
that awd is his best friend and you gotta watchout for that initial hit. Just like you would on a 1320 tree, hit it befor the green, so you leave ON green, slam down on the gas before that third honk.
I think you might be fine but one thing is that you might want to up the shot to a 125-150 just to be sure.
What the str on that 4000 stall? Efficiency? The 4000 will put you more in that sweet spot when you step on it and should have a higher shift extension. Therefore you'll hit harder and stay more in hte powerband when you shift.
good luck!!
Old Mar 4, 2006 | 04:59 PM
The Nitrous run was with the stock converter.
Here are the specs on the new one:
DESCRIPTION:
TCI®LS1 Torque Converter
TCI®’s new LS1 Torque Converter offers an easy way to deliver all that wonderful LS1 engine power to the ground. The TCI® LS1 Torque Converter delivers 95 percent efficiency; which far surpasses the OEM torque converter.
Using a 9.5-inch torque converter core, TCI® incorporates a heavy duty stator, furnace-brazed fins and a billet steel cover to create a bullet-proof converter that delivers a 2.7:1 ratio of torque multiplication. The lightweight design helps deliver quick engine response and heavy duty mounting bolts are included with every TCI® LS1 Torque Converter.
4L60E LS1 Super StreetFighter™ Lock-up 4000 RPM stall speed, 1998-Up
Old Mar 5, 2006 | 01:12 PM
slimcracka's Avatar
2.7 damn your goin to need some tires and susp..but from a roll should hit really hard..
Old Mar 7, 2006 | 08:17 PM
Thanks, any other suggestions??? Would the motor survive a 200hp shot? lol
Old Mar 7, 2006 | 08:34 PM
s346k's Avatar
if tuned correctly, yes it will survive a 200hp shot.
to run 128+ mph at what...~3600 raceweight, you'll need like 485 rwhp? or somewhere in the neighborhood...the heads/cam will probably get you close to 410 or so...add a 150 shot and you are golden. just start saving for a transmission. also, your 4k stall just became a 4800 stall on a big shot, don't forget that...
you will need some HELLA STICKY tires to hook from a 50 roll with all that power. he will hook no prob, but probably have a little turbo lag unless he brakeboosts.
torque is your friend, ESPECIALLY on the jug...i think you can take him with the heads/cam + 150 shot. (assuming it's 150rwhp)
after the 3rd honk and you hammer it activating your n2o system...can you say instant massive torque? factor this + your stall multiplying it...he won't have a snowball's chance in hell.
Old Mar 7, 2006 | 08:57 PM
Sweet, I'm really lookin foward to the race....It should be fun!!!
Old Mar 7, 2006 | 09:01 PM
SmokingWS6's Avatar
4L60e's hate wot downshifts. Particularly 4-2 or 3-2. If I'm going from a 40 to 60ish roll I'll kick it down to 2nd before the countdown and once I go wot I'll put it back in D or OD for camaro folks and let the PCM do the shifting. All this does is prevent the slippage, flair, delay experienced in a roll race while going wot from a 60 punch.
Old Mar 7, 2006 | 09:59 PM
Y2kforgedSS's Avatar
yea i wouldnt leave it in D or OD and let it down shift on that 3rd honk cause it takes that much longer for the tranny to get into 2nd. Just stick it in 2nd and let the nitrous pull you away from him. I see you winning by atleast 2 cars max but thats my opinion.
Old Mar 7, 2006 | 10:12 PM
Cool, Now I'm thinking about just using the 2.73 that my car came with....and maybe getting a smaller stall like a 3400-3600?
Just waiting for TX Speed to call me back and see what they think.. Most are sayin 3800 is the way to go. I seem to think that as long as its tunned it sould be good..
