Lock Up Solenoid
Old Feb 28, 2006 | 04:30 PM
formulajunky's Avatar
Default Lock Up Solenoid
Yeah i had a ses light at the end of last year, and was told that is why my tc wasn't locking up. Well I was told I had to replace the "lock up solenoid" but i can't seem to find one for a 4l60e, any advice would be nice on where to get this or If this can be the problem
Old Feb 28, 2006 | 05:08 PM
Anyone?? ttttt
Old Feb 28, 2006 | 07:17 PM
FLT's Avatar
FLT
OEM GM # 24230340. Hope this helps.
Old Feb 28, 2006 | 07:20 PM
FLT's Avatar
FLT
GM # 24230340. Hope this helps!!!
Old Mar 1, 2006 | 10:15 PM
2001 firehawk's Avatar
Is that what is called the b solenoid ? I just got a code that said b solenoid had a problem. Is there a place that sells a performance one?
Old Mar 1, 2006 | 10:22 PM
FLT's Avatar
FLT
No the b solenoid is a shift solenoid located in the rear of the valve body. I've never heard of hp shift solenoids. I only use OE ones.
Old Mar 2, 2006 | 05:10 PM
would this be a part that would need replacing at about 54000 miles? Would it probably just need cleaned. Sorry to steal the thread, but I need some info. You know how much and how hard to changr this part? All info much appreciated
Old Mar 3, 2006 | 12:20 PM
badcompanyvpws6's Avatar
I had the same problem. The code read "shift solenoid circuit b stuck on"
Needless to say...my trans blew two weeks later and i got it "re-inforced" I'd get that taken care of asap. Good luck.
Old Mar 3, 2006 | 12:24 PM
What was your mileage on the car. Where are you located? Lots of mods or not? Thanks for the tip it is at the shop right now.
Old Mar 3, 2006 | 06:34 PM
Q's Avatar
Q
Question, do you builders replace the shift solenoids, epc solendoid, and the lock up solenoids when you rebuild a transmission?
TIA
Old Mar 3, 2006 | 07:00 PM
chipz's Avatar
I would replace all of the electronics on the valve body.
Old Mar 3, 2006 | 10:38 PM
Q's Avatar
Q
good deal..thanks for the info.
Old Mar 3, 2006 | 11:49 PM
01_ram-air's Avatar
I just threw the shift solenoid code also. I run it at the track, spray it, and have a 4000 stall converter. It's fairly cheap and easy to replace. I did notice that the converter is locking up much better now too. Hope this helps. Oh, 67000 on the clock.
Old Mar 4, 2006 | 01:00 AM
Did it start running very weird,slipping and bogging way down when it happened?
Old Mar 4, 2006 | 01:48 AM
01_ram-air's Avatar
converter didn't want to lock up like normal. Didn't want to downshift.
Old Mar 4, 2006 | 10:37 AM
mines doing alot of weird stuff like not wanting to go in 3rd or 4th.Slipping,etc
Old Mar 5, 2006 | 05:20 PM
Red Heartbeat's Avatar
It seems the 2001 and 2002 PCMs get confused with high RPM stall convertors. Delete/Remove the tests in the PCM for codes P0757 and P0751.
