how to launch w/ a 3200 stall???
Old Mar 24, 2006 | 08:35 AM
RevGTO's Avatar
Pontiacerator
Originally Posted by Roarin_8
Don't go wot so soon. Let the car roll some then punch it.
That's what I do ... ease it off the line and then punch it. My point is that I think I could stall it up or go WOT soon with better tires.
Old Mar 24, 2006 | 10:42 AM
Roarin_8's Avatar
I have the same tires as you just different gearing. I also have a higher STR than your converter. Heat those nittos really well and they'll stick. I managed to stall at 4000, released the brakes and she still didn't spin!! Practice your technique.
Old Mar 25, 2006 | 09:59 AM
ExceSSive's Avatar
I can't believe some of you guys can't brake stall your car to 1000 RPM with a 3000TC? That does not make sense, I could brake stall my car to 1500rpm with the stock TC and now with the Yank 3200/2.1 I can stall it up to almost 2500 without the tires breaking loose. I have only been to the track once since the H/C install and got a 2.0 60', I hope to make it tomorrow if the weather clears and see if it improves much now that I have the stall in the car. I can see the difficulty in the launch now...that 2.1 makes those tires spin easily from a stop, and hittin 3200 RPM from slow rolls ie less than 30mph and the tires spin. This should be an adventure tomorrow.
Old Mar 25, 2006 | 11:10 AM
RevGTO's Avatar
Pontiacerator
You don't understand what's being said ... the problem is not brake stalling the rpm's up - the problem is hooking up when you do - the very issue you're facing.
Old Mar 26, 2006 | 01:38 PM
t1blackout's Avatar
I have had BFG's, ET Streets, and Nittos... ET Streets hook the best but the ones that I had were CRAP for driving on... My BFG's still gave me my best 60' time (1.57) although I am comparing them to my crappy worn out ET Streets.
Nittos are the best for handling and drivability in my opinion because of the wear/traction balance.
The best way I have found to launch my car (on nittos) is to push the gas pedal down at a constant speed in about 2.5 seconds. If you rev the car up with those tires you are wasting your time. Just try to balance traction with power, you should be getting 1.7 60' times with your setup I think.
Old Mar 26, 2006 | 04:28 PM
RevGTO's Avatar
Pontiacerator
Well, my ET Street Radials arrived last Friday, and the track opens next Saturday, so hopefully I'll be trying them out. Just looking at them is enough tell you they're not for the street. I'll use them to drive to the track and back and that'll be it. Nittos for daily driving during summer.
Old Mar 26, 2006 | 05:09 PM
Roarin_8's Avatar
I've noticed people stall up the converter and then release the brakes and go right into WOT, like a seesaw with their feet. You will not hook that way with nittos. Constant pedal speed like t1blackout stated is the best way with the nitto tires.
Old Mar 26, 2006 | 06:58 PM
c0ncEpT's Avatar
I have been hearing that nittos dont like to be shocked on the launch. So I would roll into the gas pretty quick and establish that traction than punch it.
Old Mar 28, 2006 | 09:43 AM
ExceSSive's Avatar
Well I have the Nitto 555 Ex not the DR and stalling it up with brake on did not work and rolling into the throttle did not work unless I just rolled to quickly. I got consistent 2.2-2.3 60's and 1 1.9 60' which was my best run of the day. I was spinning through 1st gear. The tires were definitely my limiting factor. What you need is a heated up ET street and stab and go. I watched other Camaros do it all day long with similar set ups and more power...Nitrous etc. These guys would punch it with those ET streets and would dead hook, raise the front end off the ground and go.
Old Mar 28, 2006 | 03:21 PM
1999Transamman's Avatar
definitly let the car roll a bit before you go WOT.
Old Mar 28, 2006 | 05:52 PM
slimcracka's Avatar
just get some of them M\T drag raidals...they work very well on the track and street...sounds like you need a trq. arm thow..
Old Mar 29, 2006 | 06:36 AM
  #32
ExceSSive's Avatar
There are definitely some more mods on the horizon...possibly a new cam (LGM G2), once I can get this thing to hook up.
