Drill into tranny plan to get accurate temp reading?
Old Mar 27, 2002 | 02:07 PM
FormulaWS6's Avatar
Default Drill into tranny plan to get accurate temp reading?
I am planning on installing a tranny temp gauge and was wondering if i had to drill into the pan to get an accurate reading? Would the sender have to be welded? If not, could the sender be placed on the tranny fill hole plug? Does not seem that it would be accurate there, but never know. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Mar 27, 2002 | 02:26 PM
Superman's Avatar
Default Re: Drill into tranny plan to get accurate temp reading?
My temp gauge is in the pan thru a second drain plug. I wonder where the sendor for autotap is... autotap seems to read 25* higher than my gauge.
I`ve been wanting to double check the fluid temp in the pan to make sure it my gauge reads correct ...
Old Mar 27, 2002 | 02:41 PM
Chris Spiess's Avatar
I have mine installed in the pan through a drain plug adapter as well. The factory sensor is no doubt located after the fluid has passed through the pump and valve body, probably near the exit to the radiator.
Old Mar 27, 2002 | 09:10 PM
Dave Carney's Avatar
Yep, mine's in a drain plug fitting too. Works great, always reads 10 to 15 degrees less then Autotap. That sounds about right. You can't weld or braze the fitting on. Been there, done that, the pan is made out of some sort of weird alloy. The drain kits are less than $10 and simple to install.
Old Mar 27, 2002 | 09:39 PM
FormulaWS6's Avatar
where can i get my hands on one of these drain plug kits? So, you put the sender around this aftermarket drain plug? That is all? Thanks in advance...
Old Mar 28, 2002 | 01:57 PM
FormulaWS6's Avatar
ttt
Old Mar 28, 2002 | 05:02 PM
Superman's Avatar
Most speed shops, Summit , Jegs..all carry the B&M drain plug kit.I`m sure most of the vendors too.
Old Mar 30, 2002 | 01:11 PM
Hugger's Avatar
I bought my drain plug kit from Autozone. But be careful putting it in and messing with it. Mine worked great until I had to drain the trans fluid the first time, then it leaked until I bought a new 2k Silverado pan from GM. If you are goin to put the drain plug in your stock pan I can send you some pics via email of where I put mine so that it didn't interfere with the internals of the trans.
