A4 gear calculator
Old Mar 28, 2002 | 09:40 AM
SteveC's Avatar
From: Poway, Ca. where GOD and the sun always shines
Default A4 gear calculator
Hi everyone;
Does anyone know of a website that can tell me the MPH, and RPM the A4 transmission would be doing, based on different rear end ratios.
I have the ratios of the A4 transmission.
Example: What RPM's would the engine turn at 80MPH with 4.10 rearend gears?, same question with 3.73.
Quite a while back, someone posted a sight that gave this information, however using the "search" feature, I can not find it.
Thanks in advance.
SteveC <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 28, 2002 | 10:00 AM
Vortech396's Avatar
Default Re: A4 gear calculator
Here you go Steve <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
http://www.f-body.org/gears
good luck
John
Old Mar 28, 2002 | 10:35 AM
SteveC's Avatar
Thanks so much John, that was exactley what I was looking for. Shortly I will be changing my rearend gears in my Z28 with A4 transmission, and I wanted to weigh out all my options between 3.73, and 4.10.
This gives me all the ammo I need to make the proper decision.
Old Mar 28, 2002 | 02:17 PM
Vortech396's Avatar
Steve,
Here's a couple more for you to play with. <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Speed for RPM range comparing rear gears
Speed for RPM range
later
John
Old Apr 2, 2002 | 12:36 AM
GeorgeC's Avatar
Keep in mind that with an automatic, there will always be some converter slippage, except when the torque converter is locked-up... All converters will differ on their efficiency, but a good ballpark would be around 5-6% slippage...
Just FYI... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
