Need Some Powerglide Help Please
I want to be able to Swap to the powerglide to race with, and daily drive with a T56
Basically I am asking what should i look for, Any gear ratios, certian upgrades?
I would like to have a small stall and a trans-brake also and how much it would cost to do this, correctly.
The car wieghs 3200lbs 12 bolt with 4.11's and there is no torque arm
I would also love imput from peple that have done or are currently doing this
do a search under powerglide and next - that will give you plenty of info. i did the seatrch not long ago. unless you are PURELY doing bracket racing,. a small stall powerglide is a horrible idea.
Think about how slow a stock LS1 would be with a 2-speed compared to a T56. It would go from running low 13's in the 1/4 to running mid 14's, just because of the transmission. I can't see how thats any benefit.
If you want an automatic for consistant times, go with something like a built 4L60E. At least it won't make you car slow as molasses.
go talk to eric aka "next" about his 9.7 @ 132 stock bottom end ls1 camaro with a powerglide. same care went 9.1 @ 149 with a mild 408 on a big nitrous shot.
the key is enough converter and gearing. weight and tq are less of an issue. a 4800 stall and a 4.11/28" tire is about perfect.
However, I can see how it could be made fast when you start modifying other components, such as the torque converter, rear end ratios, and adding drag slicks. I suppose with low (4.11) rear end ratios, slicks, and a high stall converter, you can really come off the line fast. After that point, I suppose the coverter keeps the engine on the boil and prevents it from bogging on the 1-2 shift. Interesting, but a completely impractical street car. My post was referring to using the car on the street, hence the reason I think you took it out of context.
One question though: In making a track-only automatic drag car, why would you want to go with a 2-speed powerglide over a built TH350?? Wouldn't the extra gear ratio be at least somewhat beneficial in the 1/4 mile?
I love NEXT's car.... I have 10 videos of it, i didnt know it was a PG though... I dont mind swapping trannys either, i wont go to the track alot, and the car isnt my daily driver... just the fact that it can be
as for streetability, no doubt its not friendly. they drive, just not as nice as a 3 speed. remember LOTS of cars had 2 speeds OEM. on the highway its NO different than a TH series combo.
for a stock car this is a non issue. nobody puts a PG in a stock ls1 lol
extremely low drivetran loss (similar to a t56)
big trap speed
weighs nothing
hammer out of the hole and hook every time
1K dollars builds you a tranny strong enough to hold a 9 second car easily. probably more depending on weight.
"Next" went 9.7 @ 132 on a sick 1.32 60' with 520 rwhp (sprayed to get that number) in his PG car.
big trap speed
weighs nothing
If you get a converter with enough stall to keep the engine in its power band, and with the right gears, a powerglide could hoe a t-56.
