t-350 w/aftermarket shifter come inside!!!
Old Mar 17, 2006 | 11:36 AM
D'scamaro's Avatar
Default t-350 w/aftermarket shifter come inside!!!
i installed a hurst pistol grip shifter with the neutral saftey switch wires on the shifter, and after i put in my t-350 and shifter the starter wont turn over, starter is good and getting power to it but it isnt engaging or spinning, what wires do i need to hook up to the shifter thanks a ton, dwayne
Old Mar 17, 2006 | 01:16 PM
00byrd's Avatar
On the side of your stock shifter there is a plastic switch around 5" long take it off and put it in neut. or park plug it in the harness and car should start I went through this same thing. Hopes this helps.
Old Mar 19, 2006 | 05:56 PM
D'scamaro's Avatar
that horseshoe looking peice?? and what two wires do i hook up to the shifter??
what harness?? becuase i only have two wires coming out of my shifter not a harness... thanks for the help though
anyone else want to chime in??? please!!!!
