So what fluid does everyone use?
Old Mar 18, 2006 | 01:50 AM
BrianC98Z28's Avatar
Default So what fluid does everyone use?
Fixing to change mine and just wanted to see what everyone reccomends? And also just how much does it hold since its a 4L65E and Vig 3600 converter. Thanks in advance.
Brian
Old Mar 18, 2006 | 07:05 AM
FLT's Avatar
FLT
I only recommend dextron III. It's cheap and works just fine. As far how much it depends on if you have a deep pan and also how long you let the tc drain back. After doing the service dump 4-5 quarts in it. Fire it up and start checking the level. When you think it is full get in the car do a few reverse and drive apply cycles. Put it park and check it. If more is needed repeat the apply cycle and go from there. I would say a service is going to take 5-8 quarts. Also when replacing the filter there is a seal in the pump if your filter fits snug just leave the seal alone. Remember to put a little grease on the snout of the filter before installing. This will make it easier to install and prevent you from damaging the seal. Alot of people have a hard time with this and it really doesn't need to be changed. Good luck...
Old Mar 18, 2006 | 07:38 AM
Dans2000SS's Avatar
Brian
Mobil 1
Old Mar 18, 2006 | 09:50 AM
01Z0H6's Avatar
Castrol ... DexIII
204K on my 4L60E with a YankSY3500..
Old Mar 18, 2006 | 10:29 AM
buffman's Avatar
I just use valvoline dexron III. works just fine for me.
Old Mar 19, 2006 | 06:43 PM
Drew778's Avatar
I'm using Castrol Type F
Old Mar 19, 2006 | 08:02 PM
Blacker's Avatar
I use Valvoline Dexron III
Old Mar 19, 2006 | 08:24 PM
Strahley's Avatar
I use Type F on my th350
Old Mar 19, 2006 | 09:28 PM
Wesmanw02's Avatar
I've heard Mobil 1 ATF is excellent
Old Mar 20, 2006 | 05:20 PM
Travis99LS1's Avatar
Originally Posted by PewterY2KZ28
Castrol ... DexIII
holy **** man thats sick... ...How often do you drop the pan and change the filter?
