no 3rd or 4th
Old Mar 20, 2006 | 04:30 PM
transam02's Avatar
Default no 3rd or 4th
Quick question, Can you use the transmission settings from an 02 f-body on a 99 without any problems?
Anway, I used my hptuners to put the default predator tranny settings from an 02 firehawk into my 99 ta. Now my car will not shift into third or fourth gear. I even tried to use hptuners to manually select the gears but I have had no luck so far. So, I guess my transmission is just gone now?
Thanks,
Morgan
Even under light loads, when my car goes to switch into third it is like my car hits neutral.
Old Mar 20, 2006 | 11:12 PM
REDWS6ROCKET's Avatar
may have burned up 3-4 clutches, very common problem!
