Stall Speed vs. 60 ft.
Old Mar 27, 2006 | 02:56 PM
n2o's Avatar
n2o
Default Stall Speed vs. 60 ft.
I know that tire/traction differences will come into play here, but I want to see what you guys are getting. The best 60' I have cut since the th400 is a 1.79. My converter is a 3500. I haven't had a chance to spray it yet but I was wondering if my hopes of low 1.6's/high 1.5's on motor are out the window. I am on MT 325's and for the record I haven't been to the track on a very warm day.
Thanks
Old Mar 27, 2006 | 04:15 PM
00ultraz28's Avatar
3600 vig here... with sportsman pros i've cut high 1.5/low 1.6.
Old Mar 27, 2006 | 04:36 PM
OctaneZ28's Avatar
Vig3200 here... Stock internal N/A LS1... 1.57 60ft on a Hoosier Slick.
Old Mar 27, 2006 | 05:07 PM
99SeanWS6's Avatar
i cut a 1.9 on nitto street tires and a TCI3000
Old Mar 27, 2006 | 05:22 PM
redsscamaroboy's Avatar
Yank PT4000,Nitto's full weight and stock internals
1.61 (All motor)
Have not tried my E/T streets,YET.
Old set-up:
Vig 3600-E/T streets(same as above: full weight etc..)
1.74 on motor
1.54 on spray
Dave
Old Mar 27, 2006 | 07:37 PM
jimmyblue's Avatar
Moderator
I think it's less about the stall speed than the STR. The short
times are about acceleration at low speed, which is torque
and torque multiplication. I see most low- to moderately
modded cars as having near flat engine torque from 3K
on up to where airflow starts to fade. So I don't think 500
RPM give or take will make the same difference as a 1.8:1
STR vs a 2.7:1, not uncommon in 4000-range converters.
Provided your tires stick that's a 50% increase in rear wheel
torque over stock, on top of any gain from being in a better
torque position.
On the negative side in this case the TH400 has a pretty
short first gear, way less than the 4L60E if memory serves
and this cuts back on your bonus.
Old Mar 27, 2006 | 09:16 PM
n2o's Avatar
n2o
It may really have a short 1st gear if I go with the trans-brake. 200 shot leaving off the brake would make things interesting.
