Shift points
Old Mar 30, 2006 | 09:33 AM
GDM Z28's Avatar
Default Shift points
i need to adjust my shift points because of my gears. i have 342's instead or the 323's....how should i adjust them from stock?
Old Mar 30, 2006 | 09:35 AM
mvonada's Avatar
Need to see you dyno sheet to make that decision
Old Mar 30, 2006 | 11:10 AM
GDM Z28's Avatar
havent dynoed the car yet. the speedo is way off because of the gears so i was told the shift points have to be changed so the car will shift ok.
Old Mar 30, 2006 | 11:16 AM
12secSS's Avatar
What do you have to reprogram the ECM. If using something like HPTuners, you simply enter the new rear gear ratio and hit auto compute and you should be done. You may want to go over them and smooth them out more to your liking.
If you do no thave a programmer, then you will need to find a shop with reprogramming capabilities or a friend that has support.
Old Mar 30, 2006 | 11:27 AM
GDM Z28's Avatar
i have a few friends that tune and im gonna try out jeremy and see how i like it but for now i just need to fix the shifting. i have hp tuners i can use. so all i do is enter the new gear ratio and it fixes everything then my WOT shifting will be fine?
Old Mar 30, 2006 | 01:01 PM
12secSS's Avatar
Correct! You may find that you will want to readjust some of the corrected setting HPT does. But the basic function HPT offers will correct your shift speeds.
Old Mar 30, 2006 | 10:41 PM
GDM Z28's Avatar
TY sir
