what will happen if you lift the wheels off the ground coming out the gate?
Is this a serious question?
Your speedo won't work for the split second your wheels are in the air. once they hit the floor and start rollin it'll work again.
I doubt it makes much of a difference, but my front littles are not exactly round with the weight of the car on them, so measure them unloaded or loaded?
As long as they are at the right pressure then it doesn't matter.
Hmm. I have a '95 T56 in an 86 SS with '95 9C1 spindles (and I kept the ABS sensors but the 1LE rotors lack the speed sensors that the 9C1 rotors had.)
