Let's play "What did I break?"
Old Apr 4, 2006 | 12:11 AM
NastyNate's Avatar
Default Let's play "What did I break?"
Correct me if I am wrong but, the transmission isn't supposed to seperate from the motor untill the converter is completely un bolted right? And I guess I need to read more on how in the F**K to get those ******* stock converter bolts out. One of the bolts stripped and the bit got stuck in it so as I was prying it out the transmission poped and moved back 3-5 inches.
Old Apr 4, 2006 | 12:16 AM
Dustin's Avatar
Are all 3 bolts bolting the flexplate to the converter seperated?
Old Apr 4, 2006 | 12:18 AM
NastyNate's Avatar
nope, thats how I am pretty sure I broke something.
Old Apr 4, 2006 | 12:33 AM
Rebelord's Avatar
you could be sliding the tranny off the converter. I'd be very careful though.
Ski
Old Apr 4, 2006 | 06:07 AM
8a8mfh's Avatar
If your very careful you can remove the transmission with the converter in place on the flexplate, then take the converter off.
It's not the way to do it, but you didn't break anything.
Old Apr 4, 2006 | 07:34 AM
NastyNate's Avatar
I guess I am just worrying way too much cause I've never seen the transmission seperate without the converter being disconnected from the flywheel. It's not like I was trying to seperate it it just popped and moved back. Normal that's a sign that my dumb 245 lb 6'3 *** just muscle fucked something alittle too hard.
Old Apr 4, 2006 | 11:51 AM
Cheatin' Chad's Avatar
The trans will come off without the converter if you have enough room for it to do so.
