Old Apr 12, 2006 | 09:25 PM
Cbrakllr's Avatar
Default 400
ok really simple question here, Could I do a 400 tranny swap going from a 4l60e to a 400 for about $2500? Thats including everthing (tranny, crossmember, drivshaft shortening, shifter) I ask because my next mod is a new tranny and I was looking at built 4l60e's but that just wont hold up to what I want so Im going to do a 350 or 400 swap whichever will hold and is cheaper. Thanks for the help in advance.
Old Apr 13, 2006 | 12:31 PM
Cbrakllr's Avatar
No one has any input?
Old Apr 13, 2006 | 12:50 PM
n2o's Avatar
n2o
Should be able to, of course it depends on how you option it. Mine was 3k installed. But I already had a torque arm that was compatible.
Old Apr 13, 2006 | 01:29 PM
Cbrakllr's Avatar
So I know I need a new crossmember, driveshaft,shifter but what about the torque arm? Could I use one from BMR? The one that they relocate it?
Old Apr 13, 2006 | 04:33 PM
n2o's Avatar
n2o
Yes sir, as long as it is mounted to the body. I re-used my spohn and I would think that yours would work fine.
Old Apr 13, 2006 | 04:37 PM
n20stroker's Avatar
Its about 1700 in parts and about 1400 for a good trans. Speed inc sells built 400. Im in the process of doing mine wasnt that bad.
Old Apr 13, 2006 | 05:16 PM
Cbrakllr's Avatar
speed inc. makes a built 400? I didnt know that they dont have it on their website.
Old Apr 14, 2006 | 07:37 AM
n20stroker's Avatar
Ya go to trans section all the way at the botton. They sell every thing u need to make the change.
Old Apr 14, 2006 | 09:44 PM
chris718's Avatar
ive got an excellent listing of th400s on my website.give it a view.we cnc machine our th400 brake valve bodies,input shaft and 36 element direct clutch drums.
Old Apr 15, 2006 | 12:44 AM
revtime's Avatar
I did my TH400 swap for about 2500.
I got most of my stuff used though.
I already had an adjustable BMR TA so I bought a BMR conversion crossmember that relocates the TA to the crossmember.
Tranny, stall, DS, and cooler were all used and bought as a package deal.
If you have patience you can find a good deal on all the parts for a conversion.
I absolutely love how it turned out by the way.
