Need any pics of trans cooler install- trans temps are heating up
Does anyone have any pics of trans cooler installs, please help.Temps reached 210 degrees with a B&M cooler mounted in front of the radiator right in the middle.
Marco
Marco
I dont have any pics, but you can mount it either in front of the radiator (where the FTRA mounts) or on the passenger side of the car opposite the air pump.
Hope this helps... <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
<small>[ April 16, 2002, 06:27 PM: Message edited by: Mike Hoffpauir ]</small>
Try mounting the cooler to the driver's side all the way across and run the lines around the radiator. I'd recommend getting the Dearle pan from JEGS.com. It holds extra fluid and has neat cooling tubes going through the bottom of the pan. Also, if you have a stall converter and it is locking up under WOT, you will get hot tranny temps because you are cutting off the flow of fluid through your system.
Good luck..
Good luck..
