6l80 in a fbody?
Old Nov 12, 2006 | 01:22 AM
performabuilt's Avatar
LS1Tech Sponsor
Everything can be done , we are studying on it now so in the future who knows
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old Nov 12, 2006 | 10:52 PM
2002_Z28_Six_Speed's Avatar
I don't get it.
Old Nov 13, 2006 | 01:46 AM
jpat1023's Avatar
how is that not on topic?
Old Nov 13, 2006 | 10:08 AM
dhdenney's Avatar
Freal dude.
Old Sep 14, 2007 | 11:18 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
So how beefy compared to the 4L60E? I'd seriously consider getting an 08 C6 with this trans if I felt like I could keep a trans alive in it with 500-600rwhp.
Originally Posted by back4more
well i went to an atra seminar on this trans and i have to tell you it is awsome. it basically is a baby allison 1000. The gearset and clutchpaks are just a smaller version, for retrofits it will be interesting to see. it also has a stock double lock up plate converter, 10" diameter. The biggest thing is that the ECU is actually in the trans. you take the pan down and there it is! so someone will have to piggyback or splice into all the factory sensors like tps to run it. The great thing with the gear spread is that you will always be in max powerband, and with such a low 1st you can probabley go the next rear end ratio( 4.10 to 3.73, or 3.73 to 3.42) and still have great launches. As far as us builders the cool part is the vb and solenoids are one unit and can be tested on the bench. That way you cna check a sticky valve or bad slenoid before the pan is put on! however if you guys think this thing is cool wait till 2008 (specifially look at the tahoe series that trans will blow all of you away! lest say 25-60% better mileage and a gain of .2 in et)
Old Sep 14, 2007 | 11:41 AM
Hennytime's Avatar
if they are putting it behind the ls3, it has to be somewhat decent of a tranny
