TA install on 10 bolt, need install specs:
Old Apr 18, 2002 | 07:29 PM
Black Sunshine/ 00SS's Avatar
Default TA install on 10 bolt, need install specs:
I bought it used, & need to know the tq specs for the bolts & the preload bearing caps.
I also got the Royal Purple 75-140 lube that I am going to add with the limited slip. I dont have alot of noise, but a little whine under load. Will this be too thick?
Old Apr 18, 2002 | 07:44 PM
99 WS6's Avatar
Default Re: TA install on 10 bolt, need install specs:
I think the specs. are: studs 10 lb/ft, nuts 60lb/ft, bolts not more than 25 lb/ft, preload not more than 5 lb/ft.
Old Apr 18, 2002 | 08:25 PM
red ws6 99's Avatar
Just did mine this weekend, the above mentioned torques are what I used.
Old Apr 19, 2002 | 12:47 AM
CKZ's Avatar
CKZ
www.installuniversity.com has an excellent write up! Where and how much was the Royal Purple?? its time for my change too...
Old Apr 19, 2002 | 08:08 AM
Got the Royal Purple at my local NAPA, but you can also get it from Thunder Racing, one of our sponsors on the right. They were a great help on everything else. Give them a call, I know I saw the RP on their web site. They even have the GM limited slip additive.
Old Apr 19, 2002 | 02:04 PM
CKZ's Avatar
CKZ
Cool thanks!
