vig 3200 power braked & moves @ 2500rpm?
I have a vig 3200, and everyone says with my charger and mods it should be stalling around 3800-4000rpm's
How do I verify what it stalls at?
I tried to power brake it and check the rpm when it moves and it moves at 2500rpm!
Re: vig 3200 power braked & moves @ 2500rpm?
you are confusing your stall speeds. the rated stall of the converter behind a mild LS1 is 3800rpm. with your ATI youd see 4200+. Now, what you foot brake it to is dependany upon gear and tire. Testing stall speed is usually done in 3rd gear (1:1) vs. you foot stalling it (brake stalling it) in 1st (3.06:1). Also, if yo tires aint sticky you WONT be holding 2500+rpm. i can stall mine to about 2500 on the street on Goodyears (Vigi3200 here).
You're fine.
You're fine.
Terry you need to have the tranny in second gear. The converter will flash to 4000-4200 with the blower. I spoke with PI yesterday about it. By the my tranny took out my converter also. PI rebuilt the Vig for $290.00 I had some parts that got welded together. It ended up being a pretty costly shift kit...
From the Yank FAQs section, the difference between brake stall and flash stall:
Flash stall is the maximum your engine's torque can stall a torque converter. In essence flash stall and full stall are nearly identical. If you had a transbrake, you could find full stall by putting your foot to the floor and reading your tach. For argument sake, let's say we're testing a 3500 stall Yank ST 3500. If you had a transbrake, you would see around 3500 rpms. If your motor was at idle and then you suddenly floored the throttle, you might see slightly more (maybe 100 rpm more) stall for a half second as the momentum of the motor's internals "flashed" the converter a small bit above its true stall rating.
Brake stall, on the other hand is a very subjective thing. For most, it's the highest stall you can achieve before your tires spin. This varies greatly based on many factors: Traction, gearing, brake clamping force, and engine torque. With a ST3500, I may only be able to get 2200rpm "brake stall" on the street with street tires...any higher rpm and the motor torque would overwhelm the tires. But if I was at the track with racing slicks on the starting line, I might be able to get 3200 brake stall before the motor torque overwhelmed the tires. See...brake stall is very subjective.
Yank rates their converters based on their intended application. A ST 3500 will stall 3500 rpms in a stock LS1. If you had a 422 and wanted a ST 3500, the converter you received would still stall 3500 because it would be built around the torque of a 422, not a stock displacement LS1. Yank checks the stall of their converters and their competitors by using either a trasmission dyno or a "tranny tricker" in the vehicle tested. With the tranny tricker, you can place the vehicle in 2nd or 3rd gear and stab the throttle to the floor...making it easy to read both flash stall and full stall.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
