What could be causing my car to fall on its face on the 2-3 shift
Old Apr 20, 2002 | 05:20 PM
Hugger's Avatar
Default What could be causing my car to fall on its face on the 2-3 shift
I am just looking for some ideas on where the problem lies. I noticed it last nite at the track, I ran 3 times and all three runs the car just really took its time goin 2-3, it almost seemed like it was hittin the rev limiter but just barely. I have just installed a new converter and deep pan. My new Yank is supposed to be a 3700 stall, and my old one was an ST3500. The new converter and some skinnies that I borrowed from a friend were the only changes made to the car. Could hotter weather played a role in this. By the way I have no Transgo, No HPP3, thanks in advance
Old Apr 21, 2002 | 03:27 PM
Ragtop 99's Avatar
Default Re: What could be causing my car to fall on its face on the 2-3 shift
Try doing some ATAP runs on the 2-3 and see what rpm your hitting. I've had that same feeling when I was just barely coming up on the limiter.
Old Apr 21, 2002 | 07:18 PM
rich's Avatar
I had it happen when the fluid got hot after a couple passes. Do you have a trans cooler? If not get one. A shift kit would help also the hpp3 won't help at wide open throttle.Good luck. Rich
Old Apr 21, 2002 | 10:40 PM
JohnSS's Avatar
man you just need to lay off the taco bell, you gained like what 130# this spring? Just loose the fat and you'll be good to go
Old Apr 22, 2002 | 12:18 AM
Chris99WS6PWTMET's Avatar
Torque Management isnt helping your shifts out either. Just adjusting the base spark retard limit to +10 in Edit made a hell of a difference in mine. Do an ATAP run and you'll be totally discouraged when you see negative timing at the shifts. Its quite sickening!!
Old Apr 22, 2002 | 02:42 AM
Toxic Texan's Avatar
Maybe your tranny is going out on ya. Read this link and it might help. <a href="https://ls1tech.com/ubb/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=002158" target="_blank">Tranny problems!!! <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> </a>
