Difference in 93-97 and 98-02 torque convertor
Old Apr 21, 2002 | 07:16 AM
ViperZ's Avatar
Default Difference in 93-97 and 98-02 torque convertor
Okay is there a difference I found a 2800 stall one to go in my 98 and was wondering if it will work? It is for the 93-97 but I do not know of any difference in the trans can someone shed some light on this for me.
Viper
Old Apr 21, 2002 | 09:02 AM
WILWAXU's Avatar
Default Re: Difference in 93-97 and 98-02 torque convertor
I'm told that the front pump is different than the later year LT1's with 4L60E's. I believe the first couple years the LT1's had a differ tranny all together. (700R4)
Old Apr 22, 2002 | 12:23 AM
Chris99WS6PWTMET's Avatar
It will not work. I'm not sure if its shaft diameter or number of splines but LT1 converters are not compatible with LS1 trannies. Call Mike Senia at Yank and I'm sure he can give you all the specifics.
Old Apr 23, 2002 | 12:19 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
93-97 LT1 will not fit into a 98-02 LS1 F-Body.
It WILL fit into 98-02 C5.
Input shaft is different.
