Will it fit..
Old Apr 30, 2006 | 12:27 AM
Hark_Z's Avatar
Default Will it fit..
On my LT1: Fuddle 3500/2.0 STR, was previously on an LS1 car. Although it is the same size for LT1's and LS1's(245mm), the site only suggests this under the LS1 section.
Will it fit...?
Old Apr 30, 2006 | 12:47 AM
Hark_Z's Avatar
anyone?
Old Apr 30, 2006 | 02:10 AM
Drew778's Avatar
No, The LT-1 has a different imput shaft from the LS-1 4L60E, I found that out the hard way.
If you put an LS-1 coverter on a LT-1 4L60E, it will slide on and seem to work, but when you put the car in gear in will not move.
This is due to the LT-1 shaft being smaller and just spinning inside the coverter.
Hope this help!!!
Old Apr 30, 2006 | 02:35 PM
Hark_Z's Avatar
Hope this help!!!
Thanks, that's what I needed to know!
