Yank SS4000
Drives Great!!! Its The Perfect Size....except When I Got Home I Got A Check Engine Light And The Trans Went Into A Failsafe Mode( Stayed In Third Gear) ...i Checked The Codes And Found Codes For Shift Solenoid Stuck Open....wtf???
Any Help Would Be Great
Just incase you get suck in 3rd and don't have a way to reset it right away, just turn the car off and restart, you'll get all gears back.
edit: And on 2nd note when i reset the PCM the **** comes back all the time
i dont want to drive my car like this boooooo Last edited by Black98Z28; May 3, 2006 at 02:47 AM.
Rex, get your LS-1 edit cable again and I can turn that code off for you!
I had mine change out and I still got the code, it's in the tune.
