Launching
Old May 11, 2006 | 11:12 PM
gccasper04's Avatar
Default Launching
got a problem...
when im at the track, I goto launch, ive got it down in first and I floor it. And the second I hit it, its liek taking off in 2nd. But when I do the same thing at the street, its takes off in first.
Also, why does first shift at 5500 when ive got my shifts set at 6000???
Old May 12, 2006 | 05:25 AM
s346k's Avatar
you're probably spinning at the track, the stall and a little spin will cause your car to shift into second immediately, at least this happens to me, as well. i lose 2-3 mph because of bogging. also, i would bet that your car shifts closer to 6k than you think, simply because the factory tach is ssllooww. my tach showed my car shifting @ 5,400 and it was really 6,050, from 1-2. 2-3 showed ~5,700 when it's really 6,050...you see the pattern.
Old May 12, 2006 | 05:28 PM
Z28_Ninja's Avatar
i am betting it is because you are bogging, but it might not be from spinning, i have bogged when i have dead hooked on et streets. it is almost like you want a little spin to keep the motor spun up.
Old May 12, 2006 | 06:00 PM
s346k's Avatar
i have a 4k stall, my motor spins up fast enough
Old May 12, 2006 | 06:37 PM
Z28_Ninja's Avatar
i bet yours does with a 4000 but he only has a art carr 3500 which is close to what i have which i s a 3200 vig and min bogs a little.
Old May 12, 2006 | 06:48 PM
gccasper04's Avatar
it flashes close to 3800...guess i'll just keep it in D for now on...
