4L60e took a dump
Old May 17, 2006 | 12:48 PM
Chaddalack's Avatar
Default 4L60e took a dump
Recently a torque converter was installed in my Z28, The torque converter was never locked inplace and was installed. To make a long story short, the car wont go into gear. I'm positive the pump is shot. My question is what kind of pump should I buy and how hard is it to install???
Old May 17, 2006 | 09:44 PM
BubaGumpShrimp's Avatar
dumb question but did you add any fluid to the trans after the install.. Check the level while the car is in park on level ground. Once the level looks ok, go in the car and put the shifter in each gear for 10 or so seconds, this allows fluid to fill the valve body which will lower the level of the trans fluid. Place shifter back in park and recheck the level..
this is just a guess as to your problem and i could be completely wrong.
Old May 17, 2006 | 11:23 PM
Chaddalack's Avatar
yepper the pump is shot.
